网站又没法搜帖子了,怎么回事?404,出现好几天了 在线,18天前提问
怎么下载文件一直失败? 在线,31天前提问
为什么登不进去 在线,57天前提问
服务器又出问题了 在线,98天前提问
签到出现问题几天了 在线,104天前提问
为什么不能签到? 在线,106天前提问
签到又有问题了吗 在线,106天前提问
从哪里下载这个监控软件? 在线,116天前提问
能同时发本5g的书么? 在线,116天前提问
Keysight World: Innovate全球创新云峰会直播链接是. 在线,137天前提问
请问直播链接是? 在线,137天前提问
请问24号的keysight的会议地址在哪里呀 在线,157天前提问
ims失败原因值 在线,180天前提问
UE RRC Inactive处于以下哪些管理状态 在线,192天前提问
alex中关于PFC的解释,本人英语水平有限,自己看看着翻译吧
4.5Quality of Service
The purpose of QoS is to differentiate resources, that is to differentiate access and bandwidth proportionally to the priority of the different user subscriptions. This is achieved with a QoS reservation and scheduling algorithm.
In the R99 standard, new procedures are introduced to let BSS negotiate the QoS with SGSN. At activation of the PDP-Context between the MS and SGSN, a QoS level is negotiated between BSS and the SGSN.
The QoS level is valid per Packet Flow Context (PFC) for an MS in BSS.
In downlink the MS can have several PFCs activated in BSS, that is an MS can have more than one application running at the same time.
In uplink there can only be one active PFC for an MS.
The inputs for the negotiation of a QoS level, are the QoS attributes and network capability. There are four main traffic classes, Background, Interactive, Streaming and Conversational where the Ericsson BSS supports Background, Interactive and Streaming:
BackgroundThe Background class is intended to be used by applications where the data is not required to arrive within a certain time, for example e-mail and file transfers.
InteractiveThe Interactive class is intended to be used by applications where the end-user is requesting data on line and thus is expecting data to arrive quite quickly, for example web-browsing. It is possible to differentiate between users in the Interactive class, 3 levels of priority are available.
StreamingThe Streaming class is intended to be used by applications where the end-user is requesting real time data such as video or audio clips. Introducing the support of the QoS traffic class Streaming makes it possible to fulfill Guaranteed Bit Rate (GBR) requirements for Streaming applications also in cells with high traffic load. Within traffic class Streaming there are two different priorities, Media Streaming and EIT Streaming.
Media Streaming has the highest priority and is used by audio-video applications with high requirements on bandwidth.
EIT Streaming is used for delay sensitive application that does not require that high bandwidth, for example applications like Push to Talk.
If Conversational is requested, it will be treated as Interactive
Ericsson BSS also supports Quality of Service for MSs and SGSNs supporting only 3GPP R97/R98 by mapping the R97/R98 specific QoS attributes onto the classes specified in R99 version of QoS.
For more information about QoS, see Reference [12].
