【资料名称】:MSA338频谱仪说明
【资料作者】:无􀀵􀀪􀀰􀀯
【资料日期】:2006-8-5
【资料格式】:PDF
MAS338频谱仪说明书
当你使用此仪器时,请观察仪器后方之注意事项􀀏􀀁􀀁
! WARNING􀀂􀀁警告􀀁在裡面的没有操作者维修的部分。􀀁呈交向合格的人员服务。􀀁要使用的规则,在手册裡熟悉􀀁􀀁
NO OPERATOR SERVICEABLE PARTS INSIDE. REFER SERVICING TO QUALIFIED PERSONNEL. PRIOR TO USE, BE FAMILIAR WITH SAFETYINSTRUCTIONS IN THE MANUAL.
! CAUTION 􀀂􀀁警告􀀁
FOR CONTINUED FIRE PROTECT, REPLACE ONLY WITH SPECIFIED TYPE’S AND RATED FUSE.
指定的類型并且评价保险丝。􀀁 13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
􀁡 For you to use it safely 安全地使用􀁡 1) When abnormal sounds, abnormal smell and smoke were confirmed, remove the battery and AC adaptor and stop the use.
当发生異常声音,異常味道及烟雾时,拔除电池和交流变压器并停止使用。􀀁􀀁
2) Never use with hands that got wet, because doing so may cause damage, fire and electric shock to the unit.
禁止以湿手使用仪器,以避免引起可能损坏,和火灾及触电。􀀁
3) Never use under the thunder, because doing so may cause damage, fire and electric shock to the unit.
禁止于雷电下使用仪器,以避免引起可能损坏,和火灾及触电。􀀁
4) Never use an AC adaptor other than the one specified, because doing so may cause damage to the unit. For static electricity protection, ground the unit by connecting the three cores if possible. Not grounding the unit can damage it and the object measured. 禁止以其它未经确认之 AC 变压器, 以避免仪器损害。未使用接地线将造成仪器损􀀁
害及测试物。􀀁
5) Never use a battery other than the one specified, because doing so may cause damage to the unit. When removing of installing the battery, be sure to do it after you turn off the unit and disconnect the AC adapter. 禁止以其它未经确认之电池, 以避免仪器损害。在移除安装好之电池时, 请务必确认􀀁
仪器已关机并拔除变压器。􀀁
