在一个ue log中看到
message measurementControlFailure :
rrc-TransactionIdentifier 2,
failureCause configurationIncomplete : NULL,
laterNonCriticalExtensions
v590NonCriticalExtensions
measurementControlFailure-v590ext
rrc-TransactionIdentifier-MSP-v590ext 0
后经过咨询rnc人员,确定是rnc参数配置问题:把异频邻区配置了readsfn=true
之前的测量控制消息如下:
message measurementControl : r3 :
measurementControl-r3
measurementIdentity 2,
measurementCommand setup : interFrequencyMeasurement :
interFreqCellInfoList
removedInterFreqCellList removeAllInterFreqCells : NULL,
newInterFreqCellList
interFreqCellID 0,
frequencyInfo
modeSpecificInfo fdd :
uarfcn-UL 9637,
uarfcn-DL 10587
cellInfo
primaryCPICH-Info
primaryScramblingCode 11
primaryCPICH-TX-Power 33,
readSFN-Indicator TRUE,
tx-DiversityIndicator FALSE
interFreqMeasQuantity
reportingCriteria interFreqReportingCriteria :
filterCoefficient fc3,
freqQualityEstimateQuantity-FDD cpich-RSCP
interFreqReportingQuantity
utra-Carrier-RSSI FALSE,
frequencyQualityEstimate FALSE,
nonFreqRelatedQuantities
dummy noReport,
cellIdentity-reportingIndicator FALSE,
cellSynchronisationInfoReportingIndicator TRUE,
cpich-Ec-N0-reportingIndicator TRUE,
cpich-RSCP-reportingIndicator TRUE,
pathloss-reportingIndicator FALSE
measurementValidity
ue-State cell-DCH
reportCriteria interFreqReportingCriteria :
interFreqEventList
event2d :
usedFreqThreshold -90,
usedFreqW 0,
hysteresis 0,
timeToTrigger ttt640,
reportingCellStatus withinActiveSet : e3
event2f :
usedFreqThreshold -30,
usedFreqW 0,
hysteresis 8,
measurementReportingMode
measurementReportTransferMode acknowledgedModeRLC,
periodicalOrEventTrigger eventTrigger
v390nonCriticalExtensions
measurementControl-v390ext
v3a0NonCriticalExtensions
measurementControl-v3a0ext
v4b0NonCriticalExtensions
measurementControl-v590ext
原因在25.331协议中有相关规定(8.4.1.3节):
1> if the IE "Read SFN indicator" included in the IE "Cell info" of an inter-frequency cell is set to TRUE and the variable UE_CAPABILITY_TRANSFERRED has the DL "Measurement capability" for "FDD measurements" set to TRUE (the UE requires DL compressed mode in order to perform measurements on FDD):
2> set the variable CONFIGURATION_INCOMPLETE to TRUE.
而ue的后续动作如下:
8.4.1.4a Configuration Incomplete
If the variable CONFIGURATION_INCOMPLETE is set to TRUE, the UE shall:
1> retain the measurement configuration that was valid before the MEASUREMENT CONTROL message was received;
1> set the IE "RRC transaction identifier" in the MEASUREMENT CONTROL FAILURE message to the value of "RRC transaction identifier" in the entry for the MEASUREMENT CONTROL message in the table "Accepted transactions" in the variable TRANSACTIONS and clear that entry;
1> clear the variable CONFIGURATION_INCOMPLETE;
1> set the cause value in IE "failure cause" to "Configuration incomplete";
1> submit the MEASUREMENT CONTROL FAILURE message to lower layers for transmission on the DCCH using AM RLC;
1> continue with any ongoing processes and procedures as if the invalid MEASUREMENT CONTROL message has not been received;
1> and the procedure ends.
