【资料成文时间】:
【语言】:EN
【页数】:124
【何人(公司)所著】:JQ
【文件格式】:PDF
【文件原名】:nokia工程模式介绍
【摘要或目录】:该说明书详细介绍了NOKIA Netmonitor的各项参数。
Contents
0.1 COPYRIGHT NOTICE........................................................................................................................5
0.2 FROM THE AUTHOR........................................................................................................................5
0.3 CHANGELOG..................................................................................................................................6
0.4 TODO...........................................................................................................................................7
0.6 STATUS...................................................................................ERROR! BOOKMARK NOT DEFINED.
0.7 CREDITS.........................................................................................................................................8
0.8 WHAT CAN OTHER PEOPLE DO?.......................................................................................................8
0.8.1 Phones needed.......................................................................................................................8
1. WHAT IS THE NOKIA NET MONITOR?.....................................................................................9
2. WHAT CAN I DO WITH THE NOKIA NET MONITOR?..........................................................9
3. WHICH NOKIA PHONES HAVE NET MONITOR?...................................................................9
4. HOW DO I ACTIVATE NET MONITOR?..................................................................................11
4.1 ENABLING NET MONITOR WITH LOGOMANAGER.........................................................................11
4.3 FIELD TEST OR ENGINEERING?.....................................................................................................12
4.4 CHECKING TO SEE IF NET MONITOR IS ENABLED..........................................................................12
5. HOW DO I USE NET MONITOR?................................................................................................13
5.1 WILL THE PHONE CONTINUE TO FUNCTION NORMALLY WITH NET MONITOR INFORMATION DISPLAYED?.......................................................................................................................................14
5.2 JUMPING DIRECTLY TO TESTS........................................................................................................14
5.3 INVALID TESTS............................................................................................................................14
5.4 VIEWING NET MONITOR INFORMATION WITH SOFTWARE.............................................................14
5.4.1 LogoManager......................................................................................................................15
6. HOW DO I REMOVE NET MONITOR?.....................................................................................15
7. LEGALITY OF NET MONITOR..................................................................................................16
8. DESCRIPTION OF TECHNICAL TERMS..................................................................................16
10. FIELD TESTS – TESTS 01 – 19...................................................................................................16
TEST 01 – SERVING CELL INFORMATION (1)......................................................................................16
TEST 02 – SERVING CELL INFORMATION (2)......................................................................................21
TEST 03 – SELECTION CHARACTERISTICS OF SERVING CELL AND NEIGHBOUR 1 AND 2.....................23
TEST 04 – SELECTION CHARACTERISTICS OF NEIGHBOUR 3, 4 AND 5.................................................24
TEST 05 – SELECTION CHARACTERISTICS OF NEIGHBOUR 6, 7, AND 8................................................25
TEST 06 – ALLOWED AND FORBIDDEN NETWORKS............................................................................27
TEST 07 – CURRENT CELL FLAGS.......................................................................................................28
TEST 08 – MULTISLOT INFORMATION.................................................................................................30
TEST 09 – MULTISLOT POWER OUTPUT..............................................................................................31
TEST 10 – TMSI, PRP, T3212 (LOCATION UPDATE) TIMER AND AFC/AGC INFORMATION..............32
TEST 11 – CELL AND LOCAL AREA INFORMATION.............................................................................33
TEST 12 – CIPHER (ENCRYPTION), HOPPING, DTX AND IMSI STATUS...............................................34
TEST 13 – DTX MODE STATUS / TOGGLE (ACTIVE).............................................................................34
TEST 14 – CHANGE SS SCREENING INDICATOR VALUE (ACTIVE).......................................................35
TEST 15 – MULTISLOT FRAMES INFORMATION (NOT FUNCTIONAL)....................................................36
TEST 17 – BTS (BASE TRANSCEIVER STATION) TEST (ACTIVE).........................................................36
TEST 18 – TOGGLE BACKLIGHTS STATUS (ACTIVE).............................................................................38
TEST 19 – CHANGE BEHAVIOUR FOR BARRED CELLS (ACTIVE)..........................................................39
11. BATTERY/POWER TESTS – TESTS 20 – 23............................................................................41
TEST 20 – BATTERY AND CHARGING INFORMATION..........................................................................41
TEST 23 – INFORMATION ABOUT BATTERY AND BATTERY USE.........................................................43
12. MISC. PHONE SOFTWARE AND STATUS INFORMATION – TESTS 30 - 39..................43
TEST 35 – REASON FOR LAST SOFTWARE RESET................................................................................44
TEST 36 – SOFTWARE RESET STATISTICS...........................................................................................44
TEST 38 – MEMORY DUMP (ACTIVE)..................................................................................................45
TEST 39 – REASON FOR LAST CALL RELEASE....................................................................................46
13. LAYER 1/LAYER 2 STATISTICS AND VARIOUS CONTROLS – TESTS 40 - 45..............50
TEST 40 – RESET HANDOVER COUNTERS (ACTIVE)............................................................................50
TEST 41 – HANDOVER COUNTERS (SINGLEBAND PHONE)...................................................................50
TEST 41 – INTER-CELL HANDOVER COUNTERS (DUALBAND PHONE)..................................................51
TEST 42 – INTRA-CELL HANDOVER COUNTERS (DUALBAND PHONE)..................................................52
TEST 43 – LAYER 2 (DATA LINK) TIMEOUT COUNTERS.....................................................................53
TEST 44 – CHANGE REVISION LEVEL (ACTIVE)..................................................................................54
TEST 45 – TOGGLE TRANSMITTER ON/OFF (ACTIVE).........................................................................55
14. MEMORY AND SIM INFORMATION – TEST 51 – 57...........................................................55
TEST 51 – INFORMATION ABOUT SIM.................................................................................................55
TEST 54, 55 – INFORMATION ABOUT MEMORY BLOCK SETS..............................................................57
TEST 56 – INFORMATION ABOUT DOUBLE MEMORY DE-ALLOCATIONS.............................................57
TEST 57 – STACK AND MEMORY STATUS BEFORE RESET....................................................................58
15. NETWORK RELATED STATISTICS – TEST 60 – 66.............................................................58
TEST 60 – RESET FIELD TEST COUNTERS (ACTIVE)............................................................................59
TEST 61 – SERVING CELL MEASUREMENT INFORMATION..................................................................59
TEST 61 – SERVING CELL MEASUREMENT INFORMATION (33XX)......................................................60
TEST 62 – NEIGHBOUR MEASUREMENT INFORMATION......................................................................60
TEST 62 – NEIGHBOUR MEASUREMENT INFORMATION (33XX)..........................................................61
TEST 63 – CALL ATTEMPTS COUNTERS..............................................................................................62
TEST 64 – LOCATION UPDATE COUNTERS..........................................................................................63
TEST 65 – SMS COUNTERS.................................................................................................................64
TEST 66 – SMS RELAY/CM LAYER COUNTERS..................................................................................66
17. PHONE SOFTWARE INFORMATION – TESTS 80 – 89........................................................67
TEST 80 – RESET TIMERS (ACTIVE)....................................................................................................67
TEST 81 – ENABLE/DISABLE TIMERS (ACTIVE)...................................................................................68
TEST 82 – VIEW TIMERS.....................................................................................................................68
TEST 83 – CHANGE INFORMATION SHOWN IN TESTS 84-87 (ACTIVE).................................................69
TEST 84,85,86,87 – INFORMATION ABOUT TASKS..............................................................................70
TEST 88 – INFORMATION ABOUT SOFTWARE VERSIONS.....................................................................71
TEST 89 – INFORMATION ABOUT HARDWARE AND TEXT VERSION.....................................................71
18. TEST 90 AND ONWARDS...........................................................................................................72
TEST 132 – STATISTICS ABOUT CALLS................................................................................................72
19. FIELD TEST (FTD) SYMBIAN APPLICATION......................................................................73
19.1 INTRODUCTION..........................................................................................................................73
19.2 INSTALLING FTD.........................................................................................................................73
19.3 USING FTD.................................................................................................................................73
19.4 ACTIVE TESTS............................................................................................................................74
20. FIELD TEST (FTD) – GROUP 1..................................................................................................75
TEST 1.1 – SERVING CELL INFORMATION (1).....................................................................................75
TEST 1.2 – SERVING CELL INFORMATION (2).....................................................................................76
TEST 1.3 – SELECTION CHARACTERISTICS OF SERVING CELL AND NEIGHBOUR 1 AND 2....................78
TEST 1.4 – SELECTION CHARACTERISTICS OF NEIGHBOUR 3, 4 AND 5................................................79
TEST 1.5 – SELECTION CHARACTERISTICS OF NEIGHBOUR 6, 7, AND 8...............................................80
TEST 1.6 – ALLOWED AND FORBIDDEN NETWORKS...........................................................................82
TEST 1.7 – CURRENT CELL FLAGS......................................................................................................83
TEST 1.8 – TMSI, PRP, T3212 (LOCATION UPDATE) TIMER INFORMATION.......................................84
TEST 1.9 – CELL AND LOCAL AREA INFORMATION............................................................................84
TEST 1.10 – CIPHER (ENCRYPTION), HOPPING, DTX AND IMSI STATUS............................................85
TEST 1.11 – DTX MODE STATUS / TOGGLE (ACTIVE)..........................................................................86
TEST 1.13 – CHANGE BEHAVIOUR FOR BARRED CELLS (ACTIVE).......................................................87
21. FIELD TEST (FTD) – GROUP 6..................................................................................................88
TEST 6.1 – GENERAL GPRS RLC/MAC INFORMATION......................................................................88
TEST 6.2 – UPLINK TBF ESTABLISHMENT INFORMATION...................................................................90
TEST 6.3 – GMM STATE INFORMATION..............................................................................................91
TEST 6.4 – GMM VALUES AND NON-DRX PARAMETERS....................................................................93
TEST 6.5 – GPRS NETWORK PARAMETERS........................................................................................94
TEST 6.6 – PCCCH PARAMETERS.......................................................................................................96
TEST 6.7 – PACKET SYSTEM INFORMATION PARAMETERS..................................................................98
TEST 6.9 – GPRS SERVING CELL AND NEIGHBOUR INFORMATION......................................................99
22. FIELD TEST (FTD) – GROUP 7................................................................................................100
TEST 7.1, 7.2 – INFORMATION ABOUT ACTIVE PDP CONTEXTS........................................................100
TEST 7.3 – RLC STATE INFORMATION..............................................................................................103
TEST 7.4 - RLC PARAMETERS..........................................................................................................105
TEST 7.5 – RLC DATA BLOCK COUNTERS.........................................................................................106
TEST 7.6 – LLC DATA BLOCK COUNTERS.........................................................................................107
TEST 7.7 – LLC CIPHERING INFORMATION.......................................................................................108
TEST 7.8, 7.9 LLC PARAMETERS......................................................................................................108
TEST 7.10 – SNDCP DATA COUNTERS..............................................................................................110
APPENDIX A – TYPICAL AUSTRALIAN GSM NETWORK CONFIGURATIONS..............111
DISCLAIMER....................................................................................................................................111
A.1 – OPTUS GSM............................................................................................................................111
A.2 – TELSTRA GSM........................................................................................................................116
A.3 – VODAFONE GSM....................................................................................................................120
