xxy4
积分 9404
帖子 848
威望 39029 个
礼品券 29 个
专家指数 -59
注册 2006-8-29 专业方向
LTE优化
发表于 2010-06-23 09:21:55
原帖由 opti_baby 于 2010-6-21 17:19:04 发表
仔细读TEMS的手册, 写得还是很详细的 Datang Phones
Before plugging in the phone, do as follows:
| Install the driver delivered with the Datang phone.
| After completing the driver installation, go to the directory <TEMS Investigation install dir>\Application and run the file DatangPostInstall.exe. This EXE writes the AT command
AT+CGDCONT=1,"IP","cmnet",,,;+CGEQREQ=1,4
to the registry, thereby accomplishing two things:
| Changing the number of available Datang ports from 3 (default) to 4 (the number of ports needed by TEMS Investigation).
| Setting the APN to the string cmnet for all Datang data modems. If you want to name the APN differently, run DatangPostInstall.exe from a Windows command prompt with the desired APN name as argument, for example: DatangPostInstall myapn. Compare section [url=mkMSITStore:C:\Program%20Files\Ascom\TEMS%20Products\TEMS%20Investigation\Application\Getting%20Started%20Manual.chm::/Investigation%20Getting%20Started.1.57.html#1401504]8.4.2[/url].
| Finally, run the file ManualUEConfig.exe which is also found under <TEMS Investigation install dir>\Application.
| Click the New button. This dialog appears:
[img]mkMSITStore:C:\Program%20Files\Ascom\TEMS%20Products\TEMS%20Investigation\Application\Getting%20Started%20Manual.chm::/images/manage_device.gif[/img]
Name
| Enter a name for the phone. (The string does not show anywhere else in TEMS Investigation.)
| Type
| Select “TD-SCDMA Datang”.
| Air Interface Port
| Select the port to use for air interface measurements. (Consult Datang documentation to find this out.)
| Data Port
| Select the port to use for data service measurements.
| AT Port
| Select the port to use for AT commands.
| Control Port
| Select the port to use for video call setup.
| UE Id Port
| Select the physical USB port here.
[2分钟拥有VIP权限和充足威望,可下载站内任何资料] [快速找到一份高薪的通信行业职位] |
