核心网技术专区
» 基于TMSI的寻呼实现
基于TMSI的寻呼实现
cc公主
资深元老
积分 30103
帖子 2577
威望 217786 个
礼品券 47 个
专家指数 3684
注册 2008-6-4
专业方向 交换维护
发表于 2009-07-24 11:31:32
以下的参数在使用或不使用TMSI的情况下对呼叫或寻呼功能产生影响。
1. 用命令 MGISP 检查参数 NOTIMSI 没有定义.
NOTMSI,Mobile subscriber identity confidentiality Used to indicate that mobile subscriber identity confidentiality function,that is TMSI allocation is not used for the mobile subscriber. See Application Information for block MAUTH
2. In DBTSP=AXEPARES,set=GSM1APTC,parameter=TIMTMSIREALLM is 40 sec (default),ensure that it is not zero.(用于TMSI号码的分配监督)
This parameter is the AXE parameter determines the value for timer T6-2. This timer supervises the TMSI reallocation procedure. The timer is started, when the LOCATION UPDATE ACCEPT message is sent and stopped, when the TMSI REALLOCATION COMPLETE message is received. When the timer expires the TMSI reallocation procedure is regarded as unsuccessful.
The availability of this AXE parameter depends on commercial agreements Value Range is 5-60 sec
3. In DBTSP=AXEPARES,set=GSMMMSC,parameter=PAGREPCT1LA.(在位置区里,被叫寻呼不成功后的重复条件)
This parameter is only valid in case of mobile-terminating calls when the AXE parameter PAGLATA = 1.
The AXE parameter is applicable for GSM 1900.
The availability of this AXE parameter depends on commercial agreements.
Value 0 indicates that paging in a location area is not repeated.
Value 1 indicates that paging in a location area is repeated with either TMSI or IMSI.
Value 2 indicates that paging in a location area is repeated with IMSI.
Value 3 indicates that paging is repeated as call delivery LATA paging with IMSI.
4. In DBTSP=AXEPARES,set=GSMMMSC,parameter=TMSILAIMSC.(决定用户进入MSC服务区后是否被分配TMSI)
This AXE parameter determines whether a TMSI is allocated for a mobile subscriber,every time the mobile subscriber moves to a new location area within the MSC/VLR,or only once when the mobile subscriber is registered in this MSC/VLR.
The parameter is only valid if the AXE parameter TMSIPAR = 1 and the mobile telephony exchange property CIPHER = 1. For details,see Application Information “Mobile Telephony Data,Changeable Exchange Adaptation”.
Value 0 indicates that TMSI is allocated only once.
Value 1 indicates that TMSI is allocated every time the mobile subscriber moves to a new location area within the MSC/VLR,that is,at every change of Location Area Identity (LAI)
5. In DBTSP=AXEPARES,set=GSMMMSC,parameter=TMSIPAR.(决定MSC是否开启TMSI寻呼功能)
This AXE parameter determines whether TMSI allocation is performed in the MSC/VLR. If the TMSI is allocated,all Base Station Controllers (BSC) must support the TMSI.
Value 0 indicates that TMSI is not allocated.
Value 1 indicates that TMSI is allocated only on encrypted connections.
Value 2 indicates that TMSI is allocated on all connections.
6. Check for any SAE for block MTMSIAN,give SAAEP:SAE=ALL,block=MTMSIAN;
I think we have to change AXE parameter TMSIPAR to 2. But last time in R8.0 when I tried to change TMSIPAR to 2,a lot of Subscriber Unreachable problem was observed.
移动偷跑流量证据:取下卡仍被消费数百兆流量(组图)
2015-10-31
APG:Burbackup fail with error Locked File 故障的处理
2015-10-28
中国人应该在1955年获诺贝尔医学奖-纪念沙眼衣原体的发现者汤飞凡
2015-10-07
TPP协议初步达成,且慢些高兴
2015-10-06
SEMTECH是怎样被HW搞倒的?
2015-09-25
一个苏北小镇长的快活饭局!(18+)
2015-09-21
xcj9811
资深元老
积分 43291
帖子 5393
威望 112890 个
注册 2007-6-21
来自 shandong
发表于 2009-08-16 18:36:17
在线,29天前提问
在线,43天前提问
在线,69天前提问
在线,110天前提问
在线,115天前提问
在线,115天前提问
在线,115天前提问
在线,117天前提问
在线,117天前提问
在线,127天前提问
在线,128天前提问
在线,149天前提问
在线,149天前提问
在线,169天前提问
在线,192天前提问
在线,204天前提问
英文资料很头疼的
youfeng
资深元老
积分 35363
帖子 4445
威望 78474 个
礼品券 98 个
专家指数 528
注册 2006-9-20
专业方向 移动通信交换
发表于 2010-03-19 11:07:44
现在是不是都开启了?
alter
积分 2548
帖子 166
威望 1926 个
专家指数 25
注册 2006-6-18
发表于 2010-04-27 17:32:27
不错的信息....
当前时区 GMT+8, 现在时间是 2024-05-09 18:12:19
Processed in 0.334908 second(s), 18 queries , Gzip enabled
