Please supply ap root login and/or password
USAGE: ./get_cell [options]
OPTIONS:
Login Parameters:
-l [login]Specify the AP login (required)
-p [Password]Specify the AP password (required)
-t [Target AP] Specify the Target AP. i.e. ap202 (optional)
-c [Central AP]Specify the Central AP. i.e. ap08 (optional)
-flx_login [login]Specify the FLX login (optional)
-flx_psswd [Psswd]Specify the FLX password (optional)
Filters:
-a Run the script on all the cells
-cell [bts1,bts2] Specify Cell/s. Comma separated List (optional)
-cdm [CDM number] Query a specific CDM (optional)
-k Keepgoing. Continues interrupted executions
-mod_onlyPerform task only on Mod1.0-3.0 cells
-1bts_onlyPerform task only on Mod4.0 cells
-crc_onlyPerform task only on CRC controllers
-urc_onlyPerform task only on URC controllers
-urc2_onlyPerform task only on URC-II controllers
-1x_only Perform task only on 3G1x cells
-do_only Perform task only on EVDO cells
-dp [CDM number]DO Parent - CDM# (optional switch)
-use_flx Uses the given flx to access the DO controllers
Actions:
-cdm_infoPrint info obtained from the DB
-umc_cmd [string] Execute the string on the UMC controller
-chk_nfd Check the NFD backplane record
-fix_nfd Fix the NFD backplane record
-gpsGet the GPS info from the timing unit
-ctu_dbg Get the CTU debug data
-gpar Get CSU Parameters
-macDisplay the MAC adrs of the controller
-evm_cmd "string" Type a command on the EVM
-put_file "string"Transfers the given file to the controller
-start_script "string"Set the startup script flag on controller
-get_pmapsRetrieve the pormap files from a controller
-upd_bootrom [UMC number]Update the Boot generic of the controller
NOTE: use 4 to update the spare on a Mod4 Frame
On Legacy frames use 2,4,6for the spares
