This version is packed with new features:
Windows Systray integration
Variable TCP port assignments
Powerful security features
Ratio (BBS style) transfers
User defineable data translation
Improved logging
Faster installation
Faster loading
Smaller memory footprint
Processing triggers
Virtual File System
Faster
More Stable
There is no fancy set up program with this version.Just UNZIP the
distribution file and run the executable.The server will set itself
up and be waiting for anonymous logons in a matter of seconds!!!
To test the server link to it using the loopback address from your
normal browser.i.e. use URL
FTP://127.0.0.1
The server can be activated and deactivated using the toolbar buttons.
User security and logging options can be set using the toolbar or
menu options.Try it and see for yourself.
This version restricts you to 2 concurrent users.
The registered version removes all restrictions.
To register go #SWREG 14010 on compuserve or see the instructions in on-line
help.
