【资料名称】:GS_MMI_IDS
【资料作者】:motorola
【资料日期】:2002
【资料语言】:英文
TABLE OF CONTENTS
1.Introduction7
1.1.Scope7
1.2.Overview7
2.Command Terminology and Formats9
3.General Service Commands12
3.1Priority Level 1 Commands12
3.1.1#12
3.1.2?12
3.1.3!!12
3.1.4CHGLEV13
3.1.5CUR_LEV13
3.1.6CLR_SCR13
3.1.7HELP(CMD)14
3.1.8HISTORY14
3.1.9MR <descriptor:AAAAAAAA(-BBBBBBBB)>15
3.1.10REPEAT <CMD> <NUM> (INT)16
3.1.11SWVER17
3.2Priority Level 2 Commands17
3.2.1DISP <LIST>17
3.2.2LOGOUT17
3.2.3MM <LIST>18
3.2.4MW <descriptor:AAAAAA(-BBBBBB)> <DATA>20
3.2.5POST_MBOX <MBOX_LIST> <
PPPPP> <XXXXXX>21
3.2.6POST_SEMA <SEMA_LIST>21
3.2.7SETBAUD <XXXXXX>21
3.2.8SET_CARRIER <CARRIER>22
3.2.9CARRIER <CARRIER> <COMMAND>22
3.2.10SET_TS <TS>22
3.2.11TSLOT <TS> <COMMAND>23
3.2.12FILTER_SET <OUTPUT_DEVICE> <MESSAGE_TYPE> <SOURCE> <DESTINATION> <MSG_BYTE_LIST>23
3.2.13FILTER_ACT <FILTER_LIST>25
3.2.14FILTER_DEACT <FILTER_LIST>25
3.2.15FILTER_DEL <FILTER_LIST>26
3.2.16FILTER_VIEW <FILTER_TYPE>26
3.2.17PRINT_MSG_HIST27
3.3Priority Level 3 Commands29
3.3.1PRINT_REG_FUNCS29
3.3.2AFN_SYNC <STATE>29
3.3.3TIME29
3.3.4COUNTERS30
3.3.5LAST_SF_TIME30
3.3.6SET_AFN <AFN>30
3.3.7SET_TIME30
4.Platform Specific Commands32
4.1Digital Hardware Commands32
4.1.0h2o_ regtest (CARRIER) (BLOCK_LIST)32
4.1.1irqtest <TEST_TYPE_LIST> (NUMBER OF SUPER FRAMES)32
4.1.2h2o_ramtest (CARRIER) (RAM_LIST)33
4.1.3ledtest <LED_TYPE_LIST>33
4.1.4wdtest <#of punches>34
4.1.5memchk <memory_type> <test_type> <verbose MODE>(AAAAAAAA(-BBBBBBBB))34
4.1.6iqtEst <
ORT_NUMBER> <LINK> <TEST TYPE> (display mode) (fp mode)35
4.1.7phylb <
HY_TYPE> <;PATTERN>36
4.1.8TDMtest <test_mode>36
4.1.9DUARTLB <;PATTERN>36
4.2Control Processor Commands36
4.2.1CAL_CONFIG <OPTION>36
4.2.2CAL_DISPLAY <CAL_ TYPE > (OPT) (OPT) (OPT) (OPT)37
4.2.3CAL_ERASE <CAL_TYPE> <SECTION>39
4.2.4CAL_HEADER <CAL_ TYPE > (OPT) (OPT) (OPT) (OPT)39
4.2.5CAL_RETRIEVE <CAL_TYPE> <SECTION>40
4.2.6CAL_RUN <CAL_ TYPE > (OPT) (OPT) (OPT) (OPT) (OPT)40
4.2.7CAL_STATUS <CAL_ TYPE > (OPT) (OPT) (OPT) (OPT)41
4.2.8CAL_STORE <CAL_TYPE> <SECTION>42
4.2.9FM_< LIST>42
4.2.10INIT <MOD_LIST>43
4.2.11IQAVG44
4.2.12PA_READ (SHORT)44
4.2.13RAMP (ON), (OFF), (DISPLAY), (LOCK), (NRM)45
4.2.14RF_BAND_DISPLAY45
4.2.15RX_VVA <BRANCH> <rx_vva, DISPLAY, LOCK, NRM>46
4.2.16SYNTH_<1, 2, NRM, DISPLAY, LOCK, HOP, HOLD, ULTRA, PSEUDO_STATIC, DSM>46
4.2.17TS <TS_LIST, TS> ANT <CTRL_LIST, X>47
4.2.18TS <TS_LIST, TS> ATXP <CTRL_LIST, XX, XX>48
4.2.19TS <TS_LIST, TS> BURST <CTRL_LIST, BRST_LIST>48
4.2.20TS <TS_LIST, TS> CHAN <CTRL_LIST, XXXX>49
4.2.21TS <TS_LIST, TS> DET_PAD <CTRL_LIST, DET_LIST>50
4.2.22TS <TS_LIST, TS> DSA <CTRL_LIST, XX>51
4.2.23TS <TS_LIST, TS> KEY <CTRL_LIST, KEY_LIST>51
4.2.24TS <TS_LIST, TS> LBK <CTRL_LIST, ON, OFF>52
4.2.25TS <TS_LIST, TS> MODULATOR <CTRL_LIST, MDLTR_LIST>53
4.2.26TS <TS_LIST, TS> MODULATION <CTRL_LIST, MOD_LIST>53
4.2.27TS <TS_LIST, TS> PA_MODE <CTRL_LIST, DUAL, COMBINED>54
4.2.28TS <TS_LIST, TS> PA_VVA <CTRL_LIST, IN, OUT>55
4.2.29TS <TS_LIST, TS> RT_PROG_ALL <CTRL_LIST, ON, OFF>55
4.2.30TS <TS_LIST, TS> RX_DSA <CTRL_LIST, X>56
4.2.31TS <TS_LIST, TS> SCALING_FACTOR <CTRL_LIST,NONE, GMSK, 8PSK, ZERO>56
4.2.32TS <TS_LIST, TS> SYNTH <CTRL_LIST, SYNTH_LIST>57
4.2.33TS <TS_LIST, TS> TSC <CTRL_LIST, X>57
4.2.34TS <TS_LIST, TS> TX_KEY <CTRL_LIST, OFF, ON>58
4.2.35TS <TS_LIST, TS> TXP <CTRL_LIST, X>58
4.2.36TS <TS_LIST, TS> VVA <CTRL_LIST, XXX>59
4.2.37Realtime Value|00000000WUC_<X:AAAAAA(-BBBBBB), Y:AAAAAA(-BBBBBB), P:AAAAAA(-BBBBBB)>60
4.2.38WUV_<X:AAAAAA(-BBBBBB), Y:AAAAAA(-BBBBBB), P:AAAAAA(-BBBBBB)>_<DATA>60
4.3Equalizer Commands61
4.3.1BER <BIT PATTERN>61
4.3.2CORR (NUMFRAMES (numsamples (start)))61
4.3.3CPINFO (NUMFRAMES)62
4.3.4Diffdec (NUMSAMPLES (START))63
4.3.5DIV (NORM, ON(_BRANCH), OFF(_BRANCH))63
4.3.6DIVCOMB(_NUMSAMPLES(_START))64
4.3.7DLCTL(_NUMFRAMES)65
4.3.8GMSKTEST_(ON, OFF)66
4.3.9HARDDECISION(_NUMSAMPLES(_START))66
4.3.10IQDATA(_NUMSAMPLES(_START))66
4.3.11ISI(_NUMFRAMES)67
4.3.12LITABLE(_NUMFRAMES)67
4.3.13MAGN(_NUMFRAMES(_numsamples))68
4.3.14MFCOEFF(_NUMFRAMES)68
4.3.15MFOUT(_numsamples(_start))69
4.3.16PM(_NUMFRAMES)69
4.3.17RTINFO (NUMFRAMES)70
4.3.18scaledinfo (NUMFRAMES)71
4.3.19SCALEDSOFT(_NUMSAMPLES(_START))71
4.3.20SIQDATA(_NUMSAMPLES(_START))71
4.3.21SOFTDECISIOn(_NUMSAMPLES(_START))72
4.3.22SPARAM(_NUMFRAMES)72
4.3.23TACORR (_NUMFRAMES)73
4.3.24UPCTL(_NUMFRAMES)73
4.4Channel Coder Commands74
4.3.25DECODE_<TYPE>_<LENGTH>_<NUM_EN_BITS>_<OUTPUT_WRDS>74
4.3.26MEMCHK SDRAM <TYPE_LIST>75
5.Group Lists76
5.1Calibration Variables76
5.2Memory Block Variables76
1.
详见资料.
